Originally Posted By: Astro14
Great car. Particularly for a kid.
Join this forum: http://www.volvoxc.com/forums/forumdisplay.php?6-2001-2007-XC70-(V70XC) The site:
http://www.volvoxc.com/ has a resources section with a ton of DIY how to guides. The 2002-2007 XC forum is very active and has some very knowledgeable folks posting there. It's a great resource.
Start reading this blog:
http://www.freewebs.com/howardsvolvos/ While Howard's car was older than yours, it had similar miles when the typical Volvo stuff began.
So, I wouldn't even check the PCV, I would simply replace it. I'll bet folding money that yours is plugged or close to it with that oil on that OCI in that engine. Get a kit like this one:
http://www.ipdusa.com/products/4991/1150...urbo-5-cylinder as old parts get brittle and break. Easier to do it all at once and replace all the parts. Figure 6 hours if this is your first PCV system. Be certain to clean the PCV passages from block to crankcase as the sludge builds up in there as well.
Check (and likely replace) the engine mounts. The passenger side mount (under the crank pulley) generally lasts 50,000 - 80,000 miles and when it fails, will result in a bit more vibration felt throughout the car. Upper engine mount (on the cross bar) has a similar life. So does the transmission torque mount. The two remaining mounts last longer, but at your car's age, I would anticipate needing them too. Don't use cheap mounts, they fail very, very quickly... Use OE or Lemforder.
Check the front control arm bushings. They seem to last about 80,000 miles and then they tear, leading to excess tire wear and sloppy handling. Easiest to replace the entire LCA if they're torn. Do the balljoints while the LCA is off.
Check your Haldex fluid and filter. With those miles, you should change them.
D&F on the transmission is a good idea. Oil sealing ring on the transmission is the same as on the oil drain plug. Get them in bulk...from IPD, the dealer wants a crazy price. Consider adding a transmission cooler. Consider adding a magnefine filter in the fluid return line from the radiator cooler. That's the setup on my wife's XC. On my V70, I went a bit more sophisticated:
http://www.volvoxc.com/forums/showthread.php?27334-02-XC70-Transmission-Flush-From-Bottom
D&F this often until the fluid looks good. Personally, I would just do a cooler line fluid exchange. Takes 14 QTs, IPD provides a nice kit with o-rings and retaining clip.
Buy a dedicated tool for the oil filter housing. I've seen them torn up from Channel Locks...IPD sells a proprietary one that works great. Assenmacher makes a cheaper one.
For oil selection, it's hard to beat the Mobil 1 0W40. Great oil, great price. Here's my UOA for a similar engine:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2281431
Pennzoil Ultra 5W40 showed great results in a UOA on my wife's 2002 XC:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2288158
Wife's XC has 202,000 on it now. Runs great. Drives like new. Looks like new. Take car of this car and your daughter will be well served for a long time to come. They're very durable, and once you sort through the few Volvo oddities/failures, they're great cars to own.
Kudos for the Lemforder recommendation! I thought I was the only BITOG'er that used or respected them lol!
Re the oil capacity discrepancy, what does the dipstick say?
