A few weeks back the Suburban starting making a droning noise from the front end. The sound usually starts when I hit 40 mph, intensifies when I let off the gas and the car begins to slow, and intensifies when turning slightly to the right while traveling at speed, such as when changing lanes. My first thought was driver-side front wheel bearing/hub assembly and that was confirmed by a local mechanic. Rather than paying them $570 to handle the replacement, I did it myself using an Amazon purchased Timkin unit (made in the USA).
I replaced the assembly this evening using new hardware (hub-to-steering knuckle bolts, axle nut, and axle nut washer) and followed the manufacturer torque specs for all parts. When I took it for a test drive, the noise was still there. What could be going on? Bad new part? That is hard to believe, considering the noise is nearly identical to what it was with the old unit. Poor install? Again, the noise has hardly changed. Misdiagnosis? Could it be the front passenger unit or perhaps a tire issue? I can try to do a tire rotation to rule out the tire issue, but cannot get to that until tomorrow evening.
Any help you can offer is greatly appreciated!
Edit: The tires are Michelin LTX M/S2 with about 15 months and 14k miles on them. They were last rotated 1,200 miles ago, which may be about when the noise started.
