This is a daily driver approximately 150 miles a day mostly highway. Also can anyone point to a resource for the low to high range for the numbers to refer to and use as a guide? Thanks in advance for your comments.
Code:
Make Kia
Engine Type 1.6 TGDI
Oil Type Amsoil Singnature Series 5W30
Miles in Use 14,486
Miles on Engine 31,962
Date of Sample 4/6/16
(ppm)
Iron 44
Chromium 1
Nickel 0
Aluminum 8
Copper 2
Lead 0
Tin 0
Cadmium 0
Silver 0
Vanadium 0
Silicon 23
Sodium 7
Potassium 19
Titanium 0
Molybdenum 134
Antimony 0
Manganese 1
Lithium 0
Boron 34
Magnesium 157
Calcium 2713
Barium 0
Phosphorous 617
Zinc 771
Contaminants % Vol
Fuel Dilution >5 - GC
Soot
Water
Fluid Properties
Viscosity 100°C CST 9.7
Base # mg KOH/g 2.22
Oxidation abs/cm 51
Nitration abs/0.1mm 19
Code:
Make Kia
Miles in Use 14,486
(ppm)
Iron 44
Chromium 1
Nickel 0
Aluminum 8
Copper 2
Lead 0
Tin 0
Cadmium 0
Silver 0
Vanadium 0
Silicon 23
Sodium 7
Potassium 19
Titanium 0
Molybdenum 134
Antimony 0
Manganese 1
Lithium 0
Boron 34
Magnesium 157
Calcium 2713
Barium 0
Phosphorous 617
Zinc 771
Contaminants % Vol
Soot
Water
Fluid Properties
Oxidation abs/cm 51
