VOA Motul 7100 4T 10W40
Portugal
Here is my VOA on a Motul 7100 4T 10W40.
I'll also publish the UOA until the end of the year, as I expect.
Thanks for posting!
Originally Posted By: ARCOgraphite
Moly in a 4t? Is this shared sump? If not did you run an oil with moly last OC?
I don't think his previous oil matters since its a VOA?
Originally Posted By: EdwardC
Thanks for posting!
Yes, this is a virgin oil analysis. To later compare the evolution with its used oil analysis.
The previous oil used (Motorex 4T 15W50) contained only 2 ppm of molybdenum after 6531 km, with a brand new genuine oil filter also. And shared sump.
Duh - sorry.
Spring-weather brain death. That my excuse THIS hour
Hi.
Another one. Same oil.
Sample sample, different results. Awkward fuel dilution results between the two labs...
And sky-high particle counting, seems almost an used oil sample on this.
