Originally Posted By: Tegger
Originally Posted By: joel95ex
as others have said, tbelt is too tight... the tightening procedure is to loose. tensioner, rotate crank so that the cam teeth move 3 notches then retighten. likely the mechanic pushed the tensioner then tightened the bolt... these tensioners are not spring loaded like GM or dodges.
This is all incorrect. The tensioner IS spring-loaded.
The factory procedure is
1) pull the tensioner down and just snug it in place temporarily
2) turn crank with tool in the normal run direction THREE TEETH and HOLD it there
3) use wrench to quickly loosen the tensioner bolt, at which point the tensioner will zing into position, then the bolt is tightened again, and torqued to its final value.
The problem with this method is that it can be extremely tight in the engine bay, and it can be hard to swing the wrench properly to make the tensioner "zing" correctly. You might end up with too little tension or too much, depending on how you do it.
I use a different procedure that takes a bit more time, but ensures a more-correct tension.
1: the method i described is what is in the honda factory manual
2: they are spring loaded to achieve the tension when the bolt is loosened, but once the bolt is tightened, the springs are no longer causing the tensioner pulley to push on the belt.
