Greetings BITOG gurus! This is my first post though I've been reading this site for several years. I finally decided I needed to join so I can ask a few questions that are weighing on my mind. I hope I can be of assistance to others in the future with whatever knowledge and experience I can offer. Thanks in advance for looking at my post.
Here's the preamble: rebuilt Cummins ISB 5.9 diesel, 2006 Dodge Ram Mega Cab 4x4. It needed a rebuild due to fractured rings and scored cylinders. I bought it used 6 years ago with 160,000 km on it. I’ve got other vehicles so I only put on about 10,000 km a year, as it’s mostly a summer travel trailer towing truck (how’s that for alliteration). The engine has new valves, camshaft, turbo, reman’d injectors, and the diesel shop said they used genuine Cummins parts. I thought I bought a good used truck but I now realize it wasn't good used, it was good and used……..
I ran Amsoil AME 15W-40 with an EAO80 (Donaldson) filter with annual OCI’s until the rebuild. The diesel shop installed Rotella T 15W-40. Here we get +30°C summers and -30°C winters, sometimes even lower. I use the engine block heater when it gets below freezing and I do use the truck in the winter. It's a long term keeper so I want to treat the new engine right.
So, here are my questions:
1. What oil brand should I be using till break in?
I plan on conventional oil until break in is complete and then switch to something synthetic, probably Amsoil AME again though I’m open to other ideas. I’ve got Shell Rotella, Chevron Ursa, Chevron Delo, Mobil Delvac, Fleet-Pro (Pinnacle Oil), Castrol GTX and Valvoline All-Fleet conventional HDEO’s easily available.
2. What oil viscosity?
Rotella’s specs show a pour point of only -30°C in both 15W-40 and 10W-30 which I find odd. Cummins says 15W-40 is OK down to -15°C, then use 10W-30. Delo and other have a lower pour point than Rotella, but does that mean they also have more friction modifiers? Aren’t less friction modifiers better until the engine is broken in?
I ran the truck for a few days of -25°C in January, and it started OK plugged in but I got scared when I realized that was only 5° above the pour point. I’m thinking I’ll use 10W-30 for the winter and 15W-40 for summer as there’s not that many viscosities available in conventional HDEO that I’m aware of.
3. What OCI?
Dodge says 6 months or 7500 miles (12,000 km). I guess 15w-40 in the spring and 10W-30 in the fall would make sense.
However, I’ve driven 4800 km (3000 miles) since the rebuild 6 months ago and I’ve needed to add 2 qts. Until the rings seat fully there’ll be more oil consumption, blowby, soot and fuel dilution. With my low annual usage should I just stick to a 6 month OCI, or are more frequent changes a good thing until broken in? If so, how often?
4. How do I know it’s broken in?
Should I follow oil consumption, and when it stabilizes I’m broken in? Would following UOA help, ie a drop in wear metals? I’d like to have some data to decide, not simply a WAG.
Sorry gents for the long first post, but I thought I should give you as much information as I can so you can give me your best answers. So fire away, I’m looking forward to getting further educated!
3. What OCI?
