Originally Posted By: Jetronic
Better safe than sorry though...
The lowest recorded temps here in modern times are -21°C. I've personally never seen that but I've witnessed -18°C a few years ago. In theory a 15w would suffice at all times, and a 20w in my reality.
but...
Oils are allowed to slip 1 winter grade during use, and 10w + 15w oils, according to Selby are more likely to show the abnormal gelling. My oil is allowed to stay in the sump for up to 2 years according to the manufacturer. If the premature gelling is caused/helped by contamination 2 year old oil will be more likely to experience this.
So the Winter rating must be chosen with care, and it might very well be appropriate to use 5w or less in my climate.
Other than that, I agree with what you're saying though.
On a side note, why does the maximum cold cranking viscosity on SAE J300 drop with the lower grades, while the low temp pumping viscosity is the same for all grades? ie, why would a 13,000 cP work at -10°C, but not at -25°C?
I agree with you, and the fact that they CAN slip "legally" makes the call to one W lower a good one (think I've recommended that one in the past too).
http://www.savantgroup.com/media/SBT-SAE-922287.pdf
Table 2 has what Selby proposed, clearly it's not what eventuated.
MRV is how well the oil gets to the pickup, I can see how that SHOULD be the same.
CCS also needs the battery to be able to do it's job, (and this is only my speculation) that the colder it gets, the less able the battery is to crank the goop.
