In a recent discussion a bitog member discussed now having to go to Firestone for his OC due to unforseen reasons. So I got to thinking and came up with a few benefits of doing so. I will use Firestone as the chain example.
Using a chain store isnt bad if you trust them. Yes you can get synthetic+filter cheap at WMart but you also have to buy gloves, paper towels or rags, cleanup sprays for any mess, clean that mess then yourself, not to mention the amount of time changing then dumping that oil at a store nearby and storing those rhino ramps. Meanwhile, Firestone will do it all for $19.99 using a great synthetic blend, and decent filter. Yes, i know you have to wait here as well.
If under warranty, you get the benefit of two receipts. One hard copy for you plus what is stored in their database. No need to worry if you lose your WMart receipt which are also prone to fade over time.
I know the satisfaction of diy is really nice but there are more ways to skin this cat and be satisfied. Just my two cents for those that always poopoo chain garages.
Thanks
Thanks
