This is a UOA from my Protege. It was run with Castrol Edge 10w30 black bottle for 5k miles driven mostly in traffic to and from work. A restore additive was used about 2 oil changes ago in an attempt to see if piston rings were causing oil consumption we couldn't trace. After adding the restore the Oil pan gasket started to leak fairly heavily. Replaced the oil pan gasket and no more consumption. This may be leftover or it may be actual bearing wear. Will check back on my next oil change. My iron seems to be low however which is good.
What does TR mean on fuel? Trace?
