Some days I check the posts and feel like I need to ask a similarly ridiculous question. So here it goes. If I haven't driven my car in a week should I do anything special to make sure I don't have extra wear at startup since so much oil has drained into the pan? I was thinking of getting an engine lift and tearing my entire engine down and soaking all the parts in oil and then putting it back together so I don't get metal on metal contact. Also, should I do something similar if I haven't driven it in 48-72 hours? I bought some QSGB for this purpose but I worry I should maybe use Royal Purple instead? I heard Royal Purple soaks into metal and creates a lubricative quality like no other. Also, I drive my car pretty hard. I really get on it making right hand turns. Probably like 3-4K RPMs. Sometimes I drive 80mph in overdrive pulling about 2500RPMs. Also, does the Bug B Gone type washer fluid work? Has anyone had issues with the fumes getting sucked into the air intake and damaging the engine? Is there an oil that works well with Bug B Gone type fluids?
