Originally Posted By: 440Magnum
Originally Posted By: asand1
Are we sure this wasn't a GHT type that didn't fill everything with saltwater and sand 4wheeling in the bay?
I had a guy come in with a 4 runner after getting stuck at a creek crossing at the beach and then sitting overnight at high tide. Transmission and engine were full sand and saltwater and it needed everything flushed thoroughly.
Don't forget it's a Jeep and there is no shortage of young and dumb.
Possible... but one thing about Jeeps is that even the 2wd models (at least the rear-drive ones, won't testify to things like the Patriot/Compass and Renegade toys) tend to have high-mounted diffy vent tubes, trans vent tubes, etc. My old 4x2 XJ and my wife's newer 4x2 WK2 both have the same high-mount vent tubes as their 4x4 brethren. The rear diff vents up by the fuel tank filler door, the front and X-fer cases on 4x models vent high up on the firewall under the hood near the brake booster. Its actually kinda hard (I won't *quite* say impossible) to get water in the gearboxes on a Wrangler unless you're arse is also sitting in river water in the driver's seat. Definitely your feet.
Hmm. I had water coming in from the bottom of the door and sucked water into the intake and didn't have any end up in the transmission!
However, the 200K mile axle seals did let some water into the differentials.
I do change, not flush, the transmission fluid, transfer case atf and gear oil quite frequently.
Most of the people I know who own or have had Jeeps.....confirm that they are "garage queens".....with very poor reliability.
Uh... not even remotely true. Both my XJs were driven hard and heavily. The '99 currently has 175,000 trouble-free miles on it.
Check out the current Consumer Reports. They get their reliability information from thousands of Jeep owners.
You must be the exception.
Cherokees were the least Chrysler Jeep built by Chrysler. AMC engines, Toyota transmissions (unless you got a 4 cylinder with auto) ... Chrysler Fuel injection system - which was decent, though. I will give them that.
Those older Jeeps - even up to the TJ - were much different than the Jeep lineup that is out now.
