Super Lube Grease
Not sure where the Super Lube tube at Harbor Freight applies here, but it sure is good when used lightly, on all my pistol friction slide-points. Maybe a wee-bit more concentrated than the typical white lithium tubes in hardware stores.
G-o-o-o-o-d stuff! I switched from using Tetra Gun Grease, which would always start-off out of the little tube as watery. No water coming out of the Super Lube upon first squeeze, for sure.
I imagine this Harbor Freight lube works on just about anything without big or heavy gears. Will try some later on a bicycle sprocket.
I use it on my bolt action rifles, it works very well.
I was surprised to learn that their standard synthetic grease with Teflon is not compatible with EPDM rubber, which is a very common type on vehicles.
I wish Harbor Freight sold the automotive, 14 ounce cartridge Super Lube as well.
