I'm researching UHP all-seasons for my Cruze. Those seem like a good compromise between improved wet braking, decent ride, and better handling. Right now the car has a set of LRR tires on it that are mediocre at everything except rolling resistance. In the 215/55-17 size and V or higher speed rating the car takes, there are two tires that are getting a hard look:
1. Continental ExtremeContact DWS06
2. Pirelli P Zero All Season Plus
I've had good luck with both brands in the past. Our Fit had a set of the original Conti DWS's that were an excellent all-around tire. My old Buick had a set of Pirelli P4's that were also a fantastic tire. So, either one is fine by me.
The roads around me are in generally okay shape. I don't drive that aggressively, but do have several high-speed turns on my commute, and an increasing number of maroon drivers that need to be compensated for.
Thoughts on those two tires?
