Originally Posted By: kschachn
Originally Posted By: NycDito
...and this is exactly why i came here for help. I was looking into oils for my 88 535i that has the need for ZDDP. All these terms are new to me, forgive me for that..flat tappet..zddp..moly etc etc. But im not new to automobiles at all. i just always used the manufacturers suggestions.
So your '88 535i wasn't back-specified to LL-01 like most everything else?
Originally called for API SF 15w40 or 15w50.
According to a BMW technical bulletin it does supersede to LL01 (because it will become NLA), Which is a 5w30 API SL/CF oil.This oil is not suggested by BMW in the owners manual. In fact the suggestion for 5w30 is for temps between -40f to +25f (degrees).
My dealer says that people ask for 15w40 all the time and that most never buy the 5w30 replacement.
From my interwebs search, SF specifically had something to do with zddp and the newer oils had less zinc as to not harm environment and Catalytics. I came to BITOG because you guys have all most likely already went through what i am going through for the first time =)
