Originally Posted By: SumpChump
THAT is my biggest concern. I'm sure they'd smugly come out and announce that they cant't or perhaps even WON'T put it back together unless I pay and additional $x,xxx to have it bored and even then ... they don't have oversized pistons for the tsb, just normal size.
Man, I have GOT to know if they are scored or not one nut can come off that engine as it'd be a total replacement and boy would they happily gouge me at any dealer who has me by the balls with an engine in pieces. "Sir, these are the facts, you decide, we are sorry that we now have found that the complimentary TSB cannot be applied, we'd be happy to put a reman engine in for you at just $x,xxx"
Most of the Toyota engines that have coked up piston rings are not scoring the cylinder walls. You are getting worked up about something that 98% of the time isn't going to be an issue with your actual engine.
But, if you want to buy/rent a borescope, feel free to knock yourself out.
Pull all 4 spark plugs, put the engine at TDC, inspect 2 cylinders, turn the crankshaft 180 degrees, inspect the other 2 cylinders, and you're done. Takes about 15 minutes.
BC.
