Make/Model: Honda 3.2L V-6 (Acura)
Fuel Type: Gasoline (Unleaded)
Oil: QSUD 0W20
Miles in use: 5328 miles
Miles: 92,000
Sample Taken: 3/9/2016
Make Up Oil: Zero qts.
Aluminum 4 -- Universal Averages 3
Chromium 1 -- 1
Iron 9 -- 10
Copper 1 -- 13
Lead 0 -- 3
Tin 2 -- 1
Molybdenum 182 -- 75
Nickel 4 -- 1
Manganese 2 -- 2
Silver 0 -- 0
Titanium 1 -- 1
Potassium 0 -- 2
Boron 27 -- 45
Silicon 4 -- 10
Sodium 5 -- 35
Calcium 2100 -- 2087
Magnesium 23 -- 192
Phosphorus 707 -- 703
Zinc 886 -- 836
Barium 0 -- 0
Values Should Be
Sus Vis @210F 55.9 -- 46-57
Cst @212F 9.05 -- 6.0-9.7
Flashpoint F 385 -- 385
Fuel TR -- Antifreeze 0.0 -- 0.0
Water 0.0 -- 0.1
Insolubles 0.3 --
Blackstone Comments: Universal averages for this type of Honda engine are based on about 5,900 miles of use. This oils was in place about the same interval, so its nice to see metals matching up as well as they do. That shows internal parts are wearing well at 92,000 total miles. You mentioned some fuel system cleaner, but that stuff gets burned up before getting to the oil, so it does not impact these results. The trace of fuel is harmless and probably idling or city driving, which is fine. The viscosity was on target and oil filtration looks great with insolubles at 0.3%. Try 7,000 miles next time.
Oil: QSUD 0W20
Miles: 92,000
Chromium 1 -- 1
Iron 9 -- 10
Copper 1 -- 13
Lead 0 -- 3
Tin 2 -- 1
Nickel 4 -- 1
Manganese 2 -- 2
Silver 0 -- 0
Titanium 1 -- 1
Potassium 0 -- 2
Boron 27 -- 45
Silicon 4 -- 10
Sodium 5 -- 35
Magnesium 23 -- 192
Zinc 886 -- 836
Barium 0 -- 0
Values Should Be
Water 0.0 -- 0.1
Insolubles 0.3 --
