Well, I guess it has finally happened... Car is consuming oil at 189,000 miles
Had this car since new and have used M1 0-20 with few exceptions for the last 175,000 miles with OCIs at roughly 5,000 miles.
At around 175,000, I noticed slight oil loss and switched to MaxLife HM. Last oil change was a few weeks ago and I'm in for about 1,000 and just added a quart. No leaks evident. Nor any smoke from exhaust to speak of...
However, unlike the normal short-tripping this car does, since the last oil change, I've had a few 200 mile highway trips with speeds in the 70 mph neighborhood. This is the bulk of the 1,000 miles put on the car since last oil change
Coincidentally, I replaced the PCV valve last oil change as well (2nd replacement) which I picked up from Rock Auto.
I suppose I have to break out some tools but it has been quite some time since I've researched anything like this and I've never opened up an engine before outside of valve cover gaskets or valve adjustment
My question: What is my plan of attack here and is it a bear of a job? Quick look on the web and I came across an Eric The Car Guy video in which he speaks of replacing valve seals and such
Could I be lucky and might there be an easy fix? I tend to over-think things like this and gravitate toward the most arduous repairs first
So bummed - this car has been fantastic from a maintenance perspective. Over 11 years So I suppose I don't have a lot to complain about
Any help or guidance will be greatly appreciated...
Thank you
Thank you
