Originally Posted By: abycat
You can run 3 different types of oil in it if you don't want to use atf. rotella 15w40 is what alot of people use. 70wt gear oil is another.
Rotella is what I would use as well.
500 hours on my YFZ450R bottom end and trans on 15w40...last time I split the cases everything was perfect. This bike is used for MX and ditch riding - 14.5 comp, ported head, YFZ cams +1 tooth, Full pipe, ect. Pulling 57hp on the dyno with e85.
Run the same oil in the R1 since 2k miles - 16k now and runs like new - Best pass is a 10.6 and sees 20-30 passes a year plus 2500 miles or so.
