2004 toy highlander
I sometimes get a strange noise under the dash- it mostlry happens when letting up on the pedal. especially when moving from a stop. the noise is a woomp noise over about 1 or 2 second as you raise your foot. it makes the noise at the start of the travel of the pedal rise only.
It does it mostly
- not when cold or first driven, works fine then
- when hot or when outside weather is hot it does it more it seem.
At the same time I get this noise the pedal seems lower and it seems the car wants to creep forward, like a bad master cylinder.
I took this problem to the dealer last year and they could never hear the noise or experience the creeping. they said all highlanders had "soft pedals" the only thing that would cause a low pedal they said was bad master cyl which they changed (expensive) did not cure it.
have there been any linkage recalls in the pedal that might cause binding or noise? would adjustment of what I think is the stoplight switch have any effect or cause lack of full pedal return and cause this condition? ?
what looks like my stop light switch (has a green plastic part that pushes on the pedal). should there be free play between the switch and the pedal?
this car had the brake piston "cup: recall, but that was on the first master cylinder.
Could power brake booster cause this, or could the cup problem have leaked fluid into the booster?
It does it mostly
