Originally Posted By: rooflessVW
They look 5 times brighter, but they're probably just a little brighter. What they are is a lot more blue, which doesn't help you see at night. I'm also interested to see your beam cutoff.
The link 901Memphis posted is spot on. I know you won't read it, so here's an excerpt:
"The most dangerous part of the attempt to "retrofit" Xenon headlamps is that sometimes you get a deceptive and illusory "improvement" in the performance of the headlamp. The performance of the headlamp is perceived to be "better" because of the much higher level of foreground lighting (on the road immediately in front of the car). However, the beam patterns produced by this kind of "conversion" virtually always give less distance light, and often an alarming lack of light where there's meant to be a relative maximum in light intensity. The result is the illusion that you can see better than you actually can, and that's not safe."
So much hate.
They are white, they were warming up when I took the picture.
Look up 6000K lights.
