I have an 01 Sable with the 3.0 Duratec that has a rear engine seal leaking. Engine has 125,000 miles on it and one shop quoted about $800 to fix it. The car is aging and I don't want to put that much into just a seal. It is likely a bigger job than I want to tackle.
Any thought on an inexpensive way to fix this problem. It is not huge but will leak a couple of drop every time I park it making spots on my driveway as well.
I was hoping to try some high mileage oil in a heavier weight and see if this helps. Might also add a stop leak product. Just looking to keep it going longer without spending too much money on it. Save the $800 for my next vehicle which may be in the next year or so.
