Hyper-Lube Oil Supplement ?
To create a higher film strength in the synthetic oil I use.
Originally Posted By: simple_gifts
What problem are you trying to solve?
With out my hearing aids my 1996 Base Toyota Tacoma is really quite . With the hearing aids the truck is a rattle can with awful wind noise.
Originally Posted By: lawnguy
Your thoughts on this product?
It would have saved everyone a lot of time if you had posted a link since any one company may have a series of different products.
My thoughts and actual physical experience?
A bottle of goo for engines on their last leg and not much mixable with motor oils.
Forms a thick blob of goo when at rest.
Originally Posted By: Ram01
Hyper-lube is a good product just like Lucas use it to extend your OCI
The HyperLube zinc replacement is a good product for racing engines and OE stuff.
The HyperLube Orange-Red Labeling bottle is a good for nothing goo.
There is no chemistry in either Lucas or this HyperLube goo to extend anything.
Dream on.
HyPer Lube is a good product.I have used it several times.In a mid 80's LTD v6 with low compression on several cylinders HyPer was in a cocktail that evened out the uneven idle.On several vehicles I used it to reduce oil loss.I think it really excels in manual trannies and rear ends.The product "cushions" and reduces felt vibration and noise in the units I have used it in.Use it at the levels indicated on the label.
Is it also just 'bright stock', and thick elastomers like the Lucas snot??
