You will be hard pressed to find the true answer, but i think yes they are since when we talked to them they have a surplus.
If you call 1-800-BEST-OIL which is 1-800-237-8645 you can be connected directly to the technical call center which has very knowledgeable people there, and if they need help the scientists are right down the hall.
