Originally Posted By: IndyIan
How is the BRZ so bad and the FRS so good?
Both seem to be on the lower end of the range for each manufacturer.
Yeah but the point being, if BRZ is the bottom end of the subaru range on the chart, FRS has to fall significantly farther to the right on the chart because the toyota bar doesn't go nearly as far down. Same production line, same everything. Except badges. Makes no sense. That said, my 2013 Dodge has had way more problems, including 5 collapsed lifters and HVAC problems before 73k miles, than my wife's Mazda, which has 72k miles and nothing but brake pads.
