bad engine mount?
Charleston, South Carolina
If you're able to watch the mount while somebody brake-checks the engine, you might be able to see the rubber pull apart, but most of the time you won't know the mount is torn in half until after the mount is out. While it's sitting there, it'll look fully intact.
I tried to do that. I wasn't able to get all the way under, mostly out of fear haha, but looking from the side, there was a lot of play in it when my wife did it.
