Originally Posted By: HTSS_TR
As Dparm said, 50W LED is actually 50W equivalent. Otherwise, the luminance of an actual 50W LED would be about 400W halogen.
I'd say this is the most likely scenario. However, if the LED does actually consume 50w of power, I'd run away. They'll be ungodly bright, but will also probably melt the back side of the bulb housing where the LED heat sink is. It's not exactly an apples-to-apples comparison, but I once used 50w halogen bulbs in fog lamps intended for 35w. About a year later, I found that the plug had melted itself to the bulb housing. Light output was nice, though
The wiring itself didn't seem to be the issue, but rather, the housing itself couldn't take the extra heat. LEDs do run much cooler than filament-based bulbs, but the heat sinks get very hot. My 9w/120v Feit bulbs at home are untouchable on the heat sink after they've been on for only an hour.
Since most modern fog lamps are pretty useless anyhow (our Fusion is an outlier), what about using a lower-powered LED in the fog lamps and using them as DRLs?
