Originally Posted By: Ihatetochangeoil
Earlye, Thanks for the insults and no help. I did what you suggested and got nowhere. Good thing I'm doing my UOA for my own info and not to impress strangers.
what insults?
none were intended.
perhaps i was unclear in my posting.
Code:
OIL GC0w30 GC0w30
MILES IN USE 4.4k 4.6k
MILES 152.5k 148.1k
SAMPLE TAKEN 10/27/07 7/21/07
ALUMINUM 2 3
CHROMIUM 0 1
IRON 12 17
COPPER 14 13
LEAD 22 19
TIN 0 0
MOLYBDENUM 6 18
NICKEL 0 1
MANGANESE 0 0
SILVER 0 0
TITANIUM 0 0
POTASSIUM 6 10
BORON 5 12
SILICON 7 9
SODIUM 19 24
CALCIUM 1866 2013
MAGNESIUM 525 424
PHOSPHORUS 842 797
ZINC 1082 1041
BARIUM 0 0
INSOLUBLES 0.4 0.3
WATER 0 0
FLASHPOINT ºF 415 395
SUS VIS 210ºF 66.8 67.7
cSt @ 212ºF 12.11 12.33
click "quote" down below, in the reply window, select and copy everything between and including
discard that window, paste into your posting, then, go through your uoa report, and replace the individual results(numbers), line by line, with your results.
is that more helpful? again, no insults intended.
and as stated, this is the "preferred" method for this forum, since the data will stay intact,nearly indefinitely, and you don't have to worry about image hosting services going down, accidentally deleting an image you are sharing, etc.
