Originally Posted By: Jetronic
I'd rather reduce oil leakage in the bearings by going up a few grades than do without the oil squirters.
Misaligned squirters are reputed to be an issue with the engine in my Nissan (ZD30 turbodiesel), and the number three pot failure...I'm not convinced, as there appear to be other issues afoot as well, but at least on the diesels, the squirters are a dead necessity these days.
Had a big post on the MC forum regarding squirters.
Looking at the typical squirter, the flow through them is going to be more dependent on pressure than viscosity. Nearly all have a length of reasonably large diameter tube (to reduce the effects of viscosity), and a short section of "nozzle", which flows according to pressure, diameter, and density with little viscosity effect.
In short, if you choose a viscosity that drops your oil pressure (e.g. BLS running AFE0w30 in his bike), squirter flow and piston cooling suffers
