So my 1975 Capri has run on various brands of 10w40 synthetic blend and some dino / mineral oils since about 1995 until last August/September, the reccomended oil for it was 20w40 or 20w50 , can it have harmed the engine in any way? the manual does say it can be run on 10w40 in very cold climates but it reccomends not to drive too agressively while running this oil , i live in southern Spain where the lowest temps would be around 0 to -5c ( high 20s / low 30s for you americans) the oil pressure is good since i switched to 20w50 and is as expected higher, a compression test showed all of the cylinders to be within spec, the reason i ran a 10w40 is because a guy at the Ford dealer reccomended it to me and at that time i thought oil was oil and that there wasn't much else to it.
The valve train on my engine does sound a bit louder than average but not worrying and it hasn't changed much over the years although 20w50 does seem to have quietened it down a bit
