The best test is the carbon pile load tester where you dial up 50% CCA and wait 15 seconds for the beep, then read the voltage off the temp compensated scale. You need the battery fully charged however for the best test. You also need to wait a few minutes for a second test, the sucker smells hot after a test. HF sells them.
The conductive testers do not require a fully charged battery and thus that is why the places that sell batteries like them. Quick test. The better (expensive) ones are temp compensated.
And don't rule out a hydrometer if you can get the cap covers off.
