When raising and lowering my cars, I have always used the pinch welds as the support points for jack stands. I jack from the front and rear center support points and lower the pinch welds directly onto the jack stands. Recently I have read that this is not the best idea because the pinch welds can bend and slotted hockey pucks/wood/etc. should be used on top of the jack stands to prevent this.
Does anyone have any thoughts on this? It would seem to me that if the pinch weld were so delicate, manufacturers wouldn't put them there. I understand how slamming the car down could bend them, but aren't they designed to support the weight of the vehicle directly when using jack stands? Is it really better to support the car using the area on the rail immediately to the left and right of the pinch weld (i.e., were you to rest the pinch weld inside of a slotted block of wood, the weight of the car would be distributed to the left and right of the weld on the rail)?
