Originally Posted By: bdcardinal
Some more recent pictures. They use fuel injection and haven't used a distributor for a few years now.
True, but the engines are still the "NASCAR spec" more than the manufacturer's design. The older versions with the distributors just clarify how far from any one manufacturer's design they really are these days. I don't like it at all, I think they should require the use of production engines- at least block/head/crank/valves. Let the Coyotes fight the LSx, iForce, and if Dodge would play again, the Hemi. Don't allow forced-induction (so no Hellcats, SuperSnakes, or Z/06), but allow race-spec pistons, valve springs, rings, intake/exhaust, EFI/ignition,dry-sump oiling, and cam profiles. Go ahead and use stock displacements, they all (except Toy) have something between 6.0 and 6.4 liters right now anyway. Robert Yates once claimed that if they did that the OHC Fords would run away with the show, but I honestly don't think that's true anymore, especially if they kept the gearing rules that didn't let anyone spin over ~8000 RPM, which is what it would take for the OHC to really gain any advantage. There'd be a hiccup and *some* manufacturer would dominate for a bit (or conversely, someone's engine would constantly blow up at a certain type track), but pretty soon they'd all settle right back to 650-700 reliable horsepower and it would be interesting again.
And for heaven's sake, just eliminate all the aero spoilers & splitters at Daytona and Talledega instead of slapping on the d*** restrictor plates. They've got cars that have relatively little power but coast forever, so it becomes all about momentum and conserving energy around the track and nobody can execute a pass unless someone else makes a mistake. Sunday was one of the worst oval-track races I've ever seen... NOTHING in the way of on-track passing other than at a restart happened until the last quarter lap. It was more of a parade than F1 sometimes is.
