Tuned up my roommates car today.
Other than the oil and the filter, the rest were off Rockauto for about 50$ S&H Included
So here we go...
Spark Plugs
Off- OEM Champion Copper (dated 2003 mind you)
In- NGK V Power
Air Filter
Off- Fram cone (totally gray sigh)
In- Firestone Closeout Warehouse filter cone
PCV
OUT- OEM (clogged to high heavens. Like, blew in it to have a JB WELD/used grease appearence to it)
In - OEM
Spark Plug Wires
Out OEM dated 2003
In - champion wires
Coil pack
Out - oem
In - whatever brand was cheaper at the time on rock auto
Oil
Out - whatever the local 10 min lube put in (or didnt)
In - QS DEFY 10w40
Oil filter
Out - some random jobber filter, ecoee design, solid green
In - Purolator Red Filter (classic)
The idle has gone down, no more rough idling, roomie bought from his now ex gf a year or two ago, the idling at fully warmed up was at 2000rpm
Now idling at 1200rpm ish
Plugs gapped to .35
Did due to noticing a bad idle while driving to and from austin with him not that long ago, checked oil levels on way back, very low, topped it off at the flying J with delo 15w40 until i could look at it.
Dropped the oil pan today too. Cleaned about a cm of sludge and cleaned with kerosene, allowing to dry replacing gaskets.
Fun morning teaching someone who relies on 10 min no name lube joints.
Oh, and his EX had gotten a "multi tune up" from a local shop
Cant explain the original PCV and Plugs though.
Hmph
So here we go...
Spark Plugs
In- NGK V Power
Air Filter
PCV
In - OEM
Spark Plug Wires
Out OEM dated 2003
In - champion wires
Coil pack
Out - oem
Oil
In - QS DEFY 10w40
Oil filter
Plugs gapped to .35
Hmph
