Seems like the syn oils w/1000ppm zddp are the norm for "consumer" synthetic oils, with 1400ppm for non-syn oils. Some of the more-specialized Joe Gibbs oils have much more zddp, but then they aren't designed for 5000+mile OCIs where engine cleanliness and deposit formation are not a real issue.
Any needed zddp past the syn 1000pm level might better depend upon the engine, its camshaft event timing, valve lift, cam follower/valve lifter type, an OEM-sourced camshaft or otherwise, and spring pressures.
CBODY67
