My transmission parking linkage is leaking transmission fluid very slowly. I have a feeling that I can use an RTV sealant to seal the rubber boot. Does anyone have a sealant in mind? Thanks in advance
The rubber boot is probably only a dirt and water shield not the actual oil seal, fixing that isn't going to stop the leak.
Do it right, get a new seal and boot, its usually not a big job. What make and model is this?
