Hi all Well, few months ago, i slammed my car door. drivers door. It appears from outside, the door looks slightly bent.The bushing on the bottom hinge had broke. it was black too..
I bought a new bolt set form autozone,comes with the copper bushings. Doorman brand. $9.99
UNbloted the door, hacked the orgigianl bolt in half, pushed it out of hinge body, and replaced in proper setting,t he bushings and bolt. I did not do the upper hinge.
Closing the door, it made it halfway too locking. but the bottom portion of door for utside still looks bent, outwards, just slightly. Do i need too also replace the upper hinge?OR did i actually bend the door? It halfway closes, but stops. FRom inside the car, the upper protion of door is making contact with car body, slightly, before the bottom half does, bottom half being from door handle ide say down.
Since im new at this..door hinges, i did a good job! Thehinges for adjusting the door outward and in, dont appear to be bent r anything. they look flush with body. Perhaps i should or need too as well, loosen the inward outward bolts and see if that adjusts the bottom hald of door too?
IM trying too figure out, what i did actualy..
