Hello again all! Pretty much as title says...my 98 corolla, developed a leak other day, ihave mostly stopped. Iferno its called, good 2000 degrees F. a putty material. The leak developed along where cat pipe meets cat body, coming from front of engine. Lost some car performace. You can tell, its time too replace it. The body is rusted, no silver or metal showing...its dead.
Now, i had noticed some smoke coming from bottom of engine..the pipe going too manifold, had some smoke coming out, but after covering catleak, it stopped, but thiers still noise coming form pipe manifold area.
Its still the original pipes and cat and muffler. Its all universal, welded together. I want too do this myslef, relace it all. But with direct , bolt it together myself. Is it possible too install direct too this car? im replacing everything including new muffkerm and resonator pipe. I have too, as the original is all welded.
im mostly looking at walker, a system kit.
