Originally Posted By: MNgopher
The Renix fuel injection - it didn't throw codes - so no check engine light. It just started running bad. Many memories troubleshooting with a multi meter...
That Renix FI system was something else. You're right, everything could be checked with a multimeter, there was no check engine light. There was a mechanical timer under the dash that you could hear clicking away anytime the ignition was in run that would turn on the main't req'd light.
My favorite part about that goofy system was the 5 second crank times!
