Originally Posted By: landtoy80
That would make sense, the gas should spread more than the oil and evaporate. I guess the rings would be from the diluted oil spreading and then gas evaporating.
I have my last oil change from couple days ago in 2 one gallon oil jugs. Do you think the test will still work? I will shake them up and see.
Glad I asked.
Should work fine. Maybe post a photo of the blotter after it sits to the next day. I always use plain white index cards and two drops of oil. The other thing is that there may be some odor to the oil with fuel in it, not sure though.
