Originally Posted By: anonobomber
When it comes to air compressors there's really no substitute for a nice big 240v compressor. I have a small 3 gal 120v that I use for my stuff that requires portability, but it is really limited. For most tasks I use my 60 gallon 3.2 HP compressor. With it I can run things like die grinders, random orbit sanders and buffers without having to stop and wait for the pressure to catch up. I'd recommend that you get as big of a compressor as you can. The 120v stuff is going to be really lackluster when it comes to running something that uses quite a bit of air like a die grinder for any length of time.
+1 Been there done that. There is nothing like a 60 gallon compressor. It was the best investment I made for my garage. I have a small 15 gallon unit next to it, that I use if I need air in the tires during the winter. For powering my impact wrenches, my rust proofing gun, grinders, air saw, air hammer, etc. the 60 gallon unit is worth its weight in gold. My only regret is I didn't buy it 35 years ago when I bought my first house.
My 15 gallon unit will operate an impact wrench for tire removal, if I have the patience to wait for it to refill. If something is really tight, its breaker bar time! It will work my rust proofing gun, with patience, a lot of patience. I wouldn't dare paint with it though, not if I'm looking for quality work.
Now that I have the 60 gallon unit I think back at the lack or power and all the time I wasted with the smaller unit. You'll probably also find that once you start using air tools, you'll want more. A small machine will severely limit what you can use in terms or air tools. Something else to consider.
