Originally Posted By: 440Magnum
No. They're more like the FMs used in ATF to prevent torque convertor clutch shudder. What they do is bring the dynamic and static coefficients of friction of the limited slip clutches closer together so that the clutch makes a smoother transition from "slipping" to "locked." Without the FM, the clutch will grab, hold, slip, repeat causing a lot of vibration and even possible wheel hop when making sharp turns.
Great explanation, thanks.
So for an open differential, with no clutch, these do not cause any adverse effect then?
