I've got an old Holley 4 barrel that I'm having problems with. I've rebuilt it and on the bench the accelerator pump seems to function fine can hear air being moved by it. After I put it on the truck and put gas in it refuses to pump it is like its frozen. You can't move the plunger no matter how hard you push it. It will remain frozen until I loosen the seal and it loses pressure then it will work freely again. This carb has the metal ball style 'check valve' and its gaped at .013 which is within spec. Any ideas?
