Originally Posted By: BlueOvalFitter
Originally Posted By: meborder
Relax,
smart [censored]. I've got a 3year old and an 8month old. When family time comes, bitog has to wait. And if the kids both get to sleep at 9pm, so do I becaus sure as [censored], ill be up at 3am (check the time stamp, I've been up for an hour already. Daughter finally went back to sleep)
Build sheet says 75. Owners manual agrees with build sheet.
( Not much of a ford guy if you don't understand what Livonia means in the Ford world.)
Which begs the question why the technical data disagree. My guess is that the engineers were referring to the trans that put behind the 4.6 and 4.2 as the 70 internally and the marketing department decided that it would be best to just call them all the same as they have done in the past.
A 4r75 behind a smaller engine will have less clutch plates than one behind a larger engine, so even though they ate called the same name, they are not interchangeable. This is true for AOD, AODE, 4r70w, 4r75, and 5r110.
So even though it has less torque capacity, some one upstairs decided they should carry the same platform name.
So, yes, they did indeed call it a 4r75, even though at one point it appears that it was more accurately called a 4r70.
(Looking at rear end....yep, it's smart!)
And, no, I am NOT much of a Ford guy
. (Is that the best dig you could come up with?) I only drive a Ford truck because IMO they are a better truck. But, I do have Chevy Orange running through my veins.
BTW, God Bless you, your children, and the rest of the family!
Wasn't a dig, just a statement of fact.
And I did make oome technical error above.
My daughter is 5 mo. Not 8. The rest is all correct, though.
Thank you for your blessings.
