2001 Honda S2000. I've owned the car for about 3000 miles. Pulled the valve cover off to check valve adjustment, check retainers, replace all the gaskets, replace the PCV valve, etc. Valves were all spot on, so that's nice. I was also able to put a camera down the spark plug holes to inspect the pistons and some of the cylinder walls; the pistons didn't have a spec of carbon on them and everything looked perfect.
Not real happy with the coloration, but I suspect a few short OCIs with M1 0W-40 will clean it up.
robert
robert
