1994 Accord 5 Speed with 232,000 miles. Wanted a filter relocation so I can continue to change my oil myself. I've developed some physical problems that make getting under there difficult, and I've unfortunately had to move significantly farther away from all the friends that usually help me out with these sorts of things. So my buddy's suggestion was a filter relocation and a fluid extractor so I could do it all from the engine bay.
Got a Trans Adapt kit single filter kit, we didn't like the included hoses and their push-type fittings, so we got these 60" hydraulic lines with custom fitting (cost more than the kit itself) and ran them essentially up and over the engine to where we fitted the new filter (Mobil 1 M1-301 Extended Performance Filter, which is significantly bigger than the stock.)
My concern is the effect of having this extra 10 feet of line snaking its way over the engine and back. Am I going to run into problems with reduced oil pressure or flow, or some other unintended consequence I haven't considered? I know it'll take oil longer to warm up and circulate on cold starts (I'm in Michigan) so I've been letting it warm up for about 2 minutes and then driving it gently until up to full operating temp.
