Originally Posted By: turtlevette
Originally Posted By: 440Magnum
Both Olds and Buicks got built with better iron (higher nickel percentage) than many Chevy blocks did.
Is there any documented proof of that? I've heard that a few times
Softer means less prone to cracks, no? I've never heard that cylinder wear was any worse with Chevy's.
As Broc said, its mostly found in interviews, writings, conversations, etc. with former engineers at the car companies. Chrysler engineering bunch in the 50s/60s was pretty proud of the low-wear properties of their block alloys, for example, so you can find a number of references to it.
And in this case "soft" doesn't mean "ductile" or "malleable," it just means "not as wear-resistant." So the higher-dose nickel blocks aren't more brittle at all, but they do resist wear better and generally have a higher Rockwell hardness.
Anecdotal observations of torn-down engines over decades tend to back up the rumors about metallurgy- Chevy engines of a certain period were well-known for having a lot less honing crosshatch left combined with bigger ridges at a given mileage than their Olds, Ford, Buick, & Mopar counterparts. Some of it might be the awful rod ratio that the SBCs above 327 CID have, which puts a lot more lateral frictional force on the piston/cylinder interface. Some of it might just be because SBCs are so numerous that abused examples seem more common than all Ford and Mopar smallblocks combined. But the odd engine from other manufacturers with simliar rod-ratio numbers (ironically, the "indestructible" 225 Slant-6 is an example, as are most Olds engines) didn't show the same kinds of wear... at least on a broad and anecdotal average.
So its a largely unsubstantiated claim, but its backed up by two independent sources (one 'insider' and one not), so I think its pretty widely accepted these days. I mean nobody goes out saying, "I really want to find a 1977 or 78 Chevy 350 core block to be the foundation of my next ultimate engine build."
FWIW, none of this really applies to the Gen-III and Gen IV GM v8s, they're a whole different kettle of fish.
