Picked up a used 3rd car for fun - 2007 BMW 328i coupe with the GM GA6L45R unit which is also used in the Cadillac ATS. Car has 190k miles.
No prior records came with the car, but Carfax shows the car was maintained by BMW dealers until 130k miles. None of the carfax records show that the car received any transmission work or fluid changes, but I'm not one to place 100% certainty on what Carfax says or does not say.
BMW claims ATF is lifetime, but I've heard of dealers recommending fluid changes at 100k. The GA6L45R fluid change includes dropping the ATF fluid sump/pan, R&R both the pan gasket and the built in filter.
My question - should I change the ATF fluid and risk potentially killing the transmission? Or just leave it alone? Is this risk somewhat mitigated since there is a built in filter that I will be changing? If I do change it, the manual recommends Dexron VI - would Maxlife ATF be okay or should I go with Valvoline or even Supertech?
Some additional thoughts - I've personally experienced a transmission that was killed after doing an ATF change. Our family's 1997 Camry 4cyl had it's first ATF change at the 120k mark. Almost immediately the transmission started shifting very roughly, and within about a hundred miles or so, we had to replace the transmission.
Since this BMW will be the 3rd car, I expect to drive it around 3-5k miles per year at most. I don't know what our long term plans are with the car - I can imagine keeping the car 3-5 years, but I can also see it going in a year or two. Regardless, given the age and mileage, my first plan is to change all fluids and filters. Just unsure whether it is safe to change the ATF fluid.
