Originally Posted By: 2015_PSD
Originally Posted By: dustyroads
2015_PSD, I hope we didn't discourage you from trying the Kendall. If you still want to give it a run, I would suggest putting it in just before one of your towing trips. That way it'll get hot and burn off the odor fairly quick.
I thought it was a good oil. I only wanted to make you aware of it's one downside and didn't intend to disparage it all together.
Not at all. I picked a 4 gallon case of it to try. I have an OC coming up later today and will probably use the Kendall. I like the brand, it has good results, and it is hard to beat that price for a synblend.
Ok cool. I'd be interested to know if you experience what JStep and myself did. I wonder if anything has changed in the chemical makeup of the Kendall that has removed the burning odor. I would gladly use it again no matter what you report but I'm curious.
Edit- if you can see your oil temp, I'd be interested to know if you see an increase in oil temps (in comparable situation) vs the T6 you have been running. The Kendall has a 4.4 HTHS and ran much hotter than anything I've run since (T6 and a couple 10W30 oils) Again, just curious.
