Originally Posted By: slacktide_bitog
Originally Posted By: Jake777
To answer that question I recently got burned by switching a older high mileage van from conventional to synthetic so honestly I'm afraid to go full synthetic.
Consider a high mileage synthetic, like M1HM or Maxlife synthetic or the new PPHM
Yep the HM synthetics are a good option.
Also, I've purchased some second hand cars that were (probably) run on conventional their whole life, but they all ended up on full synthetic oil without problem. I usually "eased" them onto full synthetic, by running one or two OCI with a semi-synthetic. I don't know if I needed to do this, but there is no problem with running a good synblend oil anyway.
I believe Valvoline has a MaxLife semi-synthetic in 5W-30 and 10W-30. These have a good rep. and are worth a try. If they work well for you, then you can try the valvoline full synthetics in 5W-30 or 10W-30 at a later stage. You can get full synthetic MaxLife.
