Originally Posted By: Ramblejam
Without an analysis, or coolant/oil temp data, we're merely going on supposition and guesswork here.
With that said, a couple of points...
Maintaining 15 PSI would be fine.
People tend to have a knee-jerk reaction to xW-50, but get all befuddled when you throw actual info their way: If your oil temp is up to 115°C (which is entirely plausible, given the turbo, thermostat setting, and catalytic converter location), that 14.2 cSt 5w-40 has fallen all the way down to 10.45 cSt.
I wouldn't have a problem with you running Mobil 1 15w-50. At 115°C, it's @ 13 cSt, which is much closer to where we'd like to be.
I have ordered an oil temperature gauge with a sender that will thread into my oil drain, so I should have sump temperatures once I actually get the time to install it.
As for coolant temperature: I noticed that my radiator fan was not kicking on as much as I would expect it to in traffic. The oil pressure would drop to just under 10psi, then the fan would kick in and it would go back up to 12 psi or so. I finally plugged in my obdII scan too and saw that coolant temp was getting up to 235F before the fans kicked in... It turns out that my low speed fan resistor is likely failed. I have ordered a new one and it comes in tomorrow.
